These are the same fans that are used on the later Spitfire too... and they aren't very efficient. Originally they were wired to continue running after the engine was shut off and the key in the "off" position.... In any event, electric fans (or even mechanical ones) don't do any good once the car is traveling over 15MPH, or so.. The problem with the Tiger is that there is nowhere for the air to escape from the engine bay.. Rootes ran the rally cars with the hood popped open. As it's hinged in the front there was no danger of it flying open.Those MG fans do not look like a very efficient blade design, but OTHO do not seem to block much of the rad core.
I wonder what the flow rate is for the pair?
There are a number of things that can be done to improve cooling. The first on my list was installing a radiator core with dimpled tubes. This slows the coolant down and holds in in the radiator longer so it can cool more efficiently. You do not want to fit a high flow water pump as this will only make the overheating problem worse. I use a 160 thermostat, have a 13lb cap, set the timing at about 12-15 degrees before TDC and set the carb slightly rich. Lean mixtures will cause the engine to run hotter, as will the timing being too far advanced. I have the 6 blade Maverick fan, and I have fit a reduced diameter water pump pulley (Robert Straghan--hoghead makes these). I also fit horn hole blanking plates, and as I have a MK2, I have an oil cooler.. I am also running stock exhaust manifolds, but with a 2" exhaust system.
Perhaps the single most effective thing I did was fit an LAT type hood, though I made mine from steel. My engine temps dropped by 15 degrees (F) from this alone. I live in north central Washington in a semi arid desert environment that usually has three weeks over 100 degrees in the summer. I had a Tiger pal come over who was dubious of the effectiveness of the hood. There were Willow leaves in the hood exhaust vents, when I started the car, the air flow from the mechanical fan blew them all out... Pretty obvious demonstration of their benefit!
The engine temp never gets above the center of the temp gauge, even on the hottest of days. In stop and go traffic in Seattle it has never overheated. I drive the car between 5-6000 miles a year and have NEVER overheated...
