Tiger64
I'm putting together a 5-bolt 289 for my Mark IA and want to go with an F4B manifold and an Autolite 4100 (1.08) on it. How have other people set up the PCV ? I've got the 1" spacer for the 4 barrel with the water passage through it but it will be too tall to fit under the hood with a stock breather. If the vacuum ports on the back of the manifold are used the PCV is vented into 1 or 2 cylinders only. Can a "T" fitting in the line from the breather cap to the bottom of the air filter housing be used? Thanks, Chris.
