Does the MK then have different rivets?The riverts used in the cross body cars square corner band mkia/ii have a part in the centre instead of a hollow hole. It stops water going in and gives them a distinctive look. Rootes used them on several cars and used them on the fresh air ventilation boxes on Sv Alpines mkia and mkii
Yes. MK1's used a tubular rivet with a smaller outer diameter head and as they don't seem to rust, I suspect that they are stainless. They are both a 1/8" rivet. The blind rivets (aluminum) were introduced in approximately June/July 1965 based on my observations. The prototype Mk1a (B9479975PPLRXFE) had the later blind rivets (aluminum). These were also used everywhere else on the car that originally had rivets. attached is a pic of the original rivets on my Mk2Does the MK then have different rivets?
I suppose it only matters if you have a bent towards how the cars actually were... Personally, I couldn't care less what someone does on their own accord... But, If they'd like to know what was original and where to source the bits, I'm here to help.How many owners see 100% factory correct as a requirement for enjoyment of the cars and what is the number of cars out there that fall into the factory correct category?
And tubular according to SeanI've been told that MK 1's had plated steel rivets.
The link won't open.You can see the later style VIN riverts on the car in this thread as they also used them on the cross body SIVA / SV Alpines too:
https://www.catmbr.org/cat-forum/th...s-v-alpine-parts-car-for-500-in-wichita.7310/
How many factory correct Tigers were at SUNI in September? How many points shy of a perfect score was the first place stock tiger ?I suppose it only matters if you have a bent towards how the cars actually were... Personally, I couldn't care less what someone does on their own accord... But, If they'd like to know what was original and where to source the bits, I'm here to help.
the steel ones are readily available and common. I had to search a bit for the blind rivets, but was able to eventually find them on-line. it may be different for those who live closer to civilization! I live in NE Bumfuckistan, so finding them at a hardware store was an impossibility.And tubular according to Sean
Is this then not a common rivet?
They're also commonly found on the trap door hinges for the fuel pump (battery on the Alpine)I got some really correct ones in the past. Chuck Daly had a bag of them and I pictured them in an album here. I've found sever later rivets stuck under carpets in the tar paper over the years but I've given them all away to my bros...
Never were they ever meant to be passed off as not removed nor to be other than original appearance. No body shop wants to take the time to paint around the tags. It a major pain to gently lift a tag thin wire method and feather paint underneath..
If you look at most any Tiger the original blind rivet will be in the part that hooks onto the windshield that the convertible top frame slips into. That piece is almost never removed and painted around. That's the later rivet, as pictured.
Steel on the earlier ones.
I guess that's the problem if someone just posts a link to a Craigslist/ ebay etc ad and doesnt bother adding some details or photos to the post.. Nust a dead link of no use to anyone....The link won't open.
