You would hook the test light to the gauge REGULATOR output and a good ground.
If the test light is coming on when the ignition switch is in the off position, you are either hooked up to the wrong place or you have another more serious electrical system wiring problem. This is more than likely what is causing your fuel gauge malfunction. I suspect that you might be getting 12v going directly to the fuel gauge and bypassing the gauge regulator. Your jostling the wires around under there may be why it is behaving differently from yesterday.
Forget trying to adapt an aftermarket fuel gauge. None of the aftermarket fuel gauges are compatible.
Regulator/stabilizer, same thing. It shouldn't be getting power when the ignition switch is in the off position, you have a wiring problem.Ok, thanks!
Found the instrument voltage stabilizer; if that's the regulator then I haven't exposed my total lack of electrical knowledge.
With the ignition switch on, the test light would not illuminate.
With the ignition switch off, the test light illuminated solid (did not blink) at each pole of the instrument voltage stabilizer.
Looks like time to invest in a yard stick until I get back to Atlanta.
Thanks again,
Allan Ballard
. I filed grooves on mine to indicate 2 gallon increments.
