Wanted Limited slip
TigerBob86
I'm looking for a limited slip for my stock Dana 44. I think Auburn made/makes one.
Thanks,
Bob
bobdixon at frii dot com
Thanks,
Bob
I just bought an Auburn and on sale now at Summit for 400 shipped
It will most likely have 3/8 carrier bolts to accept the ring gear and stock ring gear is 7/16. The fix is Jag conversion shouldered bolts made for just this purpose, or sleeves.
Easy enough
If you are buying a US ring gear then it will most likely be 3/8 and no problem......However the spline count will be wrong.
See my post regarding ring bolt sizes and the fix for the splines using a Dana Spicer "companion flange" and yoke
