lower gen bracket
Pic tomorrow
do you make them-can you send pic-Thx-Bryan
Yup: We copy the originals . examples are at the shop and will take a pic See the usual suspects that are found in the Tiger . Both generator and alternator (or modified) are represented. Pick yer poison.
One,
I need one of your adjusting arms for a very early MK I..The one I need is between 10-11" long..Not a linear measurement but more or less end point to end point.
Let me know how much they are..and how to pay you...
Shipping will be to 75072 North Texas
You could send me a PayPal invoice
kenmattice6@gmail.com
Regards,
Ken
I have one of your top ones(extra) I thought it might be for a mk2- parts number is C6OE-A I'll trade you for a gen. style that I need for my MK1 Bryan
Know whacha got
One,
Regards,
Ken
The 10145-A (dog leg) version can have several years prefixes, from C3AE thru C7 etc. It has the correct offsets for the MK1/1A w/generator. The straight version of the same length also fits w/off sets. The longer straight is for use with the common alternator mount found in most Tigers where the alternator sits high to the right of the rocker cover. CAUTION: certain water pumps DO NOT have the early base mount for the bracket. As the man says, "check the application".
Sort the puzzle
Bryan: If your dog-leg bracket has the offsets, it will work with a stock Tiger geno/water pump configuration. The base mount will need to be one of the higher bolts on the water pump so the angle/arch does not interfere with adjustment travel at the geno end. The adjustment end of bracket & bolt are behind and underneath the geno. OR, I can sell one of our straights.
I guess i'll have to wait until I get my generator back from overhaul to see what fits- how much do you want for a straight bracket-Bryan
Bench Time
The short straight critter chews up $42 in bench/fab time. Plus shipping.
