Hello all. My stock MKII runs well when cold but after about 15miles dies like it's fuel starved. Starts back up but dies shortly thereafter as I limp home. Changed needle valves, adjusted float levels (Holley 4B 80783-1), tightened the sheet metal screw holding the ground wire on the LP SU fuel pump, pulled fuel line to fill a glass jar. Can hear the pumping ticking away so presume the points are operational. That all seems fine but I'm open to your ideas. Couldn't find a fuel filter in the usual locations (b4 Fuel pump/b4 carb) so guessing that they didn't add one back during the restoration. Thinking of adding an electronic fuel pressure gauge to monitor the pressure when it craps out.
A few have suggested that it may be electrical and change the condenser in the DP Distributor (C5OF-12131-B). Out of desperation, I took it to the local speed shop that says that they specialize in American muscle so figured that they'd know a 289. Turns out they like EFI and didn't know much about carbs but offered to take a look. Found plug 1 wire was loose. Aside from effing up my interior door handle (grr), they suggested changing the Ballast Resistor to see if that helps. Hmm.
Again, it runs strong when first starting out but STB after it gets hot. If I left anything out that would help in the diagnosis, let me know.
Steve
7034994886
Steve
7034994886
