Modifying Throttle Pedal Assembly
Carbuilder
This is one of those not leaving (almost) good enough alone projects. I have the dash area all apart and removed the throttle pedal assembly. It works well enough, but the idea of the steel shaft turning in a metal plate with a hole drilled through it just didn't seem quite good enough. So...
The various pieces:
The shaft rotates in the hole; metal on metal:
I bored the holes to take a flanged bearing with an OD of 7/8". The ID is 3/8" which is the shaft size. Didn't leave a lot of material around the holes, but with the bearings installed with Loctite it would be strong enough:
Bearings installed:
Reassembled and perfectly smooth rotating action with no play:
Nice work... @sandy had posted plans of a bushed pedal a while back , seems a nice upgrade for the tactile parts of driving.
I built Sandy's assembly using rod ends, and goes well in a modified car - this one using a bearing is stealthy
The various pieces:
Bearings installed:
Reassembled and perfect smooth rotating action with no play:
Nice work. Anything to make it smoother. Never thought of the flanged bearings, good idea!
Sandy
Out of curiosity, do you have any special plans for dealing with the vertical piece that attaches to the carb rod/cable?
Buck
Buck
Robert made a new one that uses a collar clamp welded to a new rod, really looks good. I also made one out of an aluminum arm with a piece of metal to extend it a bit, I think the aluminum arm was from Speedway. Anything has to be better than the stock one. Let me see if I can dig up a picture of what I did, but if you want to make one better start like Roberts with a steel split collar TIG welded to an arm.
Buck - Look at my website for some pics here for the hack that I did. I don't have a pic of Robert's, but I can get one in the next day or so depending on the Super Storm ;)
https://gtsparkplugs.com/sunbeam-tiger-throttle-linkage.html
Some shots of the hacked linkage arm I got from Speedway. I am going to use a Lokar cable pull for my car if that matters.
Sandy
Buck
Don't have a picture of it right now, but mine has one of those ball things on the throttle pedal vertical piece and the mating snap part on the rod. Probably not a great description but I'll take a picture when I'm in the garage and the lift is down. Don't know what the stock setup is/was.
