Update
Jim Lindner came over to give me a helping hand today.
Started with TDC: It turned out I was 180 degrees off.
Next: Set cold lash for mechanical lifters.
Put back together: Verified plugs/wires.
Started engine: Very smooth, but runs at 5000-5500 rpm so cut the engine with the ignition switch. Pegged the stock tach. :------
Verified timing and rpm with timing light and engine analyzer: @ 10 BTDC and 5000+ rpm.
What is the consensus; timing or carb?
Thinking that if I advance dist to make it 14-16 BTDC for hipo that it would run faster, so didn't mess with the dist any more.
Started messing with the carb some, but decided to give it a rest after a day of putting the engine back together and getting it started/running.
Now I think it is a matter of fine tuning after listening to your helpful hints.
Regards,
Regards,
