I am getting ready to install the newly rebuilt original 260 engine and have a couple of questions
Should the oil pressures gauge line be bled of air or should it have an air cushion ?
The exhaust manifolds are installed with out the double tab washers , should i install the new ones that I bought or leave them with regular washers ? The main reason I ask is the torque spec in the manual is 16 foot pounds My thoughts were to put the double tab washers on with the 14 pounds spec and then retorque after a few heat cycles then lock with the tabs Any thoughts?
I bought a new SS exhaust system and want to know if the straighter down pipe is on the driver’s side ?
