oil pressure pipe sealing at gauge
wstote
When installing the pipe it appears an o ring may be needed. Can someone advise me.
Thanks Wes.
Redbaron
Hi Wes,
there should be a small fibre washer on the spigot of the oil pressure gauge to seal under the pipe fitting.
You may be able to fashion a thin washer from gasket paper to form a seal.
Oil Pressure Pipe Sealing at Gauge
As Redbaron has said, there should be a gasket there. The original, according to the Alpine Parts Manual, was cork. See the listing for the oil pressure gauges and gasket.
wstote
oil pressure sealing at gauge
Thanks for the info.I have made one.Hope it does the job.
Wes
