parts
Bryan
hello-friend of mine recently passed away and wife wants it all gone- most of the parts were from the wood brothers stuff from 25 years ago- there's a lot both tiger and alpine- I've been hauling everything I can - there is alpine crossmembers- suspension- brake parts- windshield frames- doors deck lids- he had two tigers cars- one early car= and one body only car which has been painted and thats it- I'm in auburn ca/ thats where the car/parts will end up- email me if you want any thing -I'll see if I have it- I'm going to bring some stuff to the convention in june at sacramento cal --Bryan merlin99@att.net
Bryon,
Do you have a set of original oil filter hoses??
Ken
(214) 856 - 5124
yes I have- there air 3 different lengths- I have all three Bryan
Oil Filter Hoses
Bryon,
I did not know there were three lengths. My car is a very very early MK1.
Do you have a good set for that car...If so let me know what you want for them and I will gladly buy them...
Regards
Ken
update- many parts that I don't need-
compete dana 44 rear end-used- 2.88 gears --new in box dana gear set 2.73--one mk2 headlight cover(chrome)--several stock oil filter set ups(hoses trashed)-fuel pump brackets-mk2 and mk1--slave cylinder brackets--used wiring harness mk2--blower motors- window wiper assy.-generator brackets= used su fuel pumps--jacks----alpine oil cooler-- send list I might have it--Bryan
Bryan,
I need to drivers side window mechanism
Would you have it in your parts pile?
Bruce
parts to go
still have parts to clear out- many l/h doors with window reg installed-front windshield frames (cheap)- heater cores(12) heater/blower motors- front wheel hubs and spinals- convert frame- hardtop headliner bows- disc brake calibers(used)16p- a lot of windshield motor assys. -- 1 hood and 1 deck lid- used- ! orginal pos battery cable good condition- a lot of headlight buckets (early) with clips for early cars serval used au fuel pumps-give a call- your'll never know until you ask?
Oil Hosing
Hey Bryan: I make the oil filter hoses and like to use the 180 degree top bend from the old hoses. It's easier than twisting my own pipe. How many ya got?
Let me check I think I have 2-your taking about the 180 degree hard pipe?
Also have many clutch and brake pedals front and rear bumper brackets- a box load of horns- 2- driveshafts- alpine axle shafts-- 1 tiger axle shaft- hardtop Black with all hardware newly painted- 1 lucus headlight works hi-low beam- alpine under dash harness(blue color wrapping)-- cowling cover plates and latches
took 7 doors apart- have a lot of window regulators early and late- rights and left--doors are so-so shape- only one early(left door) -- a lot of trunk springs- name your color-- a pile of intake grills for cowling- steering column covers- one steering column and a steering column tube-
found 6 2-bl carbs c7af as (tag) 2- c5zf-b( base plate)= and holly 1707 2s
parts to go
how much and in what condition is the P battery cable?
