I installed my soft top boot this weekend. I feel really good about the material and quality of the stitching, but I suspect there is an ERROR IN THE PATTERN. I saw this before I began the physical installation but figured, worst case, I would not hook the grommet over the stud at the back. Now that I’m finished, it has occurred to me that it may flap in the wind and will not function as originaly was intended.
Here is what I have found: The area where the grommet is located does not extend across the zipper line far enough to hook over the tonneau stud without excessive stretching. The tendency to pull a straight line under this tension causes a big pucker. I didn’t install the snap yet. If I install the snap while it is in tension then it will pucker in toward the car interior and also wads the zipper up. If I install the snap with the material pulled to create the intended radius along the outside then the edge will curl up as it returns to a straight line.
I have photos (2a, 3a, and 4a) of the original piece snapped in place and there is little to no tension on it and the grommet is across the zipper line. Photo (1a) shows the new one laying flat, not hooked to the post, and in no tension. You can see that it is about 1 inch from the stud and does not cross the zipper line. In photos (6a, and 7a) it is stretched tight to hook over the stud. As you can see, it pulls a straight line. In photo (8a) they are both attached to the front stud to depict the difference in the locations of the grommet in question.
I think it is obvious that for it to work as well as the original, the new one should lay flat with no tension. I should also mention that the right and left sides are exactly the same.
Has anyone else ran in to this same problem?
