On the way to work this morning a ticking noise started from the top end of my cars engine. It sounds just like a badly adjusted tappet and is coming from under the rocker cover for cylinders one to four. The noise started after a brief period of acceleration at three quarters throttle up to about 4000 rpm. The noise continued at all engine speeds for a couple of minutes and then disappeared. The ticking is now present for a few seconds when I first start the car, however I haven’t had a chance to run it on the road again yet.
The oil level is fine (although not absolutely up to the ‘max’ mark on the dip stick) although it’s been nearly a year since the last oil & filter change so I’m planning to carry this job out tomorrow.
I assume there is some problem with one of the tappets, but is it serious? The car is needed for a 90 mile run this Sunday.
