Anyone know ? Need to get a die - sucker put up one heck of a fight to get it to loosen up .. looks like a 5/8 - 18 but hoping someone can confirm before I use the wrong one (been there, done that ..)
5/8-18 is correct it is UNF -18Anyone know ? Need to get a die - sucker put up one heck of a fight to get it to loosen up .. looks like a 5/8 - 18 but hoping someone can confirm before I use the wrong one (been there, done that ..)
Don’t forget to tighten the lock nut with the car on its tires and on level ground and only slight compression on the rubber5/8-18 is correct it is UNF -18
3/8 -24 UNF - nuts are used
The other end is a 7/16-20 UNF bolt
So part number46 from David’s diagram has a 3/8-24 one end and 5/8-18 on the other end
Better get a high speed steel die and not a carbon steel die coz it is going to be an alloy steel part maybe grade 5 or 7Anyone know ? Need to get a die - sucker put up one heck of a fight to get it to loosen up .. looks like a 5/8 - 18 but hoping someone can confirm before I use the wrong one (been there, done that ..)
