13 vs 14 sidebar
How much does the pressure raise the boiling point? Well, it’s about 2-3 degrees for every psi that we increase the pressure of the system. Therefore, by using a 1.1 bar cap we make the average boiling point of a stock cooling system somewhere closer to around 257-260 degrees.
From
http://www.tuneruniversity.com/blog...at-advantage-of-a-high-pressure-radiator-cap/
Gene, maybe most likely should have been "a bunch of the time", with a your results may vary thrown in. The old blocks do give up a lot of rust and cast iron especially if left to sit with weak fluid. I only brought it up as I have seen it ignored too much by my friends that should know better. It is really popular to bash the car with its history while ignoring the obvious.
I agree with the math the temps, and can remember having 8lb caps in my old cars. Never really had hot rods but beach cruiser drop top cars that drank tap water and coolant. The practice of adding a higher pressure cap to a system when it didn't really need it as there were other problems, as it is much easier to add band aids with a higher cap or a fan or otherwise complain about the cars history of overheating.
Yes, I will should have stayed blocks away from the concours 13 vs 14 lb discussion. I would be a poor judge only penalizing the ones with the red levers. 1000 pardons for the sidebar to you all's thread.
The creator of the Gano filter would have not sold very many if the problem did not exist. I am sure having a visible one on a car would get a deduction in points.
And yes, maybe the shop notes should say did you clean the core when you did your radiator. Or maybe some engineer type could calculate the increased cooling area when you turn the heater on.
I do not have superior intuitive intellect just from a family who drove pick ups and old cars and had to deal with their problems. I am sure many of the younger crowd did not have the advantage of going to auto shop and learning stuff that would clog and pollute the brain later in life. I did read a lot of Tiger archive e mail postings that cite the dangers of adding a higher pressure cap and the bulging of the heater core. I do not know if that is in the shop notes cause I do not own one, Dave are you done yet?
