Dan Walters discovered a strange parts problem that might effect any of us.
When trying to trace an engine misfire, we were about to replace a rotor when Dan noticed that the two looked different. He ended up chucking a rod the size of a distributor shaft into the lathe and placed the black rotor on it. It fit snugly. Then he moved a cutting tool so that it just made contact with the tip of the rotor.
(pictured below)
Later he removed that rotor and inserted a blue one. He did not move the tool. There was a large gap between the tip of the rotor and the tool. The gap measured .084".
(also pictured below)
Has anyone else noticed variations in rotor sizes supplied for Ford distributors?
(pictured below)
