Super frustrating. So. What’s are the tricks needed for removal from the stock remote location?
Pic attached showing vise grip on top of filter. I can’t get it to budge. The holding bracket had been loosened but not enough play in the lines to allow me to lift the filter out of area. Also if I tilt, I’m risking rad hose into fan blades. Not enough room to get filter cup wrench underneath, but I’m about to try and force it. The fittings on top don’t want to give me other options. The larger nut needs channellock size, no room. The smaller allows access but I can’t seem to turn it either direction using a lot of force. I may have bent the U fitting slightly with my force.
Loosened overflow tank and moved aside to allow greater access. Still no joy.
Thanks for comments.
