Moondoggie
Here is what Edelbrock has to say on their web site :
Edelbrock High Performance Water Pumps
Edelbrock Victor Series water pumps provide maximum cooling for the street and the race track. They're ideal to prevent overheating in street rods and street machines, as well as in tow rigs and motorhomes. Using state-of-theart racing technology, Edelbrock has designed these "super cooling" water pumps to provide maximum flow, maximum pressure and equal distribution to both sides of the engine block within 1%. Available for most popular applications, these high-performance pumps flow in only one direction for optimum efficiency. The casting's computer-designed internal passages and precision powdered metal impeller produce the maximum flow rate possible. Standard and reverse rotation pumps are available for most Chevrolets, Fords, and Chryslers.
They balance the the flow on both sides of the block within 1%.....
Duke. If you move coolant thru the radiator slowly then the heat build up in the heads and cylinder region get over heated and you produce steam and hot spots. You can't move coolant thru a radiator so fast that it becomes ineffient
in a small block Ford engine in fact faster is better and more effient...
Moondoggie
Moondoggie
